Looking For An Application To Convert Physical Machine To Virtual Machine.
Hey all,
I want to use the Virtualization Technology on my Personal Computer. I want an Application to Convert Physical Machine to Virtual Machine.
Someone, please suggest me a decent Software for this purpose.
Answered By 160 points N/A #86073
I would suggest you to go for VMware P2V Converter. It is used to Convert your Physical machine to VMware Virtual Machine. You can download the Application from
https://www.vmware.com/products/converter.html.
It provides a good Performance, and is known for its reliability in the field of Virtualization Implementation. It comes with Centralized Console for Management that allows the user to manage Multiple Machines at a time.
You should go for the VMware Converter.
