Looking for an Asus USB locker
I have just bought a new Asus laptop, I plan to keep very sensitive data on it, does anyone know of an Asus USB locker that I can use to keep my files safe?
Hello Brady, To disable your USB Port, you don't need to download any kind of software. If you are using a windows operating system, you can simply follow the below steps to disable your USB.
Right click My Computer > choose Manage > choose Device Manager in left pane > look for USB Root Hub > Right Click and Disable the device. To enable the device you can follow the same steps and click enable in the last step.
Hello Brady! Good Day!
Do you want to lock you USB drive files? or the files in your laptop?
Well, there are a lot of software that protects all types of removable devices (USB Drive, Memory Sticks, External HD, Memory cards). You can use:
• USB Locker
• USB Secure
• ID USB Lock
• Lock It Easy and many more
https://en.softonic.com/s/usb-lock
There are also that can lock your file in you computer.Â
Thanks you all for helping me. Laarni Hall you mention many software, among this I was amazed by Easy File Locker. The reason is that I want to hide and lock my most sensitive files and folders and with Easy File Locker I can do it easily.
Using this now, I am able to protect my data and I am feeling safe. Your download helped me to download this software easily.
Again thanks Laarni Hall.
