Looking for autorun html file on Mac cd player instructions
Hi guys,
I have created an html cd presentation with video. I know how to auto play this on Windows but not in Mac. I need your instructions to autorun html file on mac cd player. Appreciate your help.
Best Answer by goerge rait
Answered By 5 points N/A #163721
It’s looking complicated because html cd presentation can be successfully working on Windows OS easily. It will require a virtual windows environment on MAC such as Bootcamp or VMware. You can double click on player.html file on CD for MAC. If further problem persists adjust your Flash Player security. Hope the suggestion would be useful for you.
Answered By 0 points N/A #163722
   If you want to auto run html file on mac so you should have compatible scrum tool of mac in which you can run your HTML script there are many tools available on Mac for programming in which you can run your HTML script easily like eclipse.
Thanks
