m williumm
10 points
Posted on - 07/20/2016
Hey everyone,
My Pressure Washer is not working smoothly. It runs on a Four-Stroke Engine. I found out some Engine Oils but they were all supposed to work in Six-Stroke Engines. Someone, recommend me the Best Oil for Small Engines.
Looking For The Best Oil For Small Engines For e.g. Pressure Washer.
Engine oils are different for Four-Stroke and Six-Stroke Engines. You should use “AMSOIL Formula Four-Stroke Synthetic Small Engine Oil.” It is especially for the engines that are not intended to have Routine Maintenances. It is available for Rs 620. Its formula contains the synthetic oils.
The usage of this Engine oil reduces the lubricate consumption of the Engine and makes it Heat Resistant.
This product does not put any adverse effect on the health too, if used for the purpose for which it designed.
I will advise you to use this Small Engine Oil.
