Hi everyone.
I am looking for a Free and Legal to use DVD re-writable software that can also burn or create ISO images. I need one that can support the buffer under run or buffer underflow technology too and ensure high quality recording. Any suggestions or ideas? Thanks.
Jay Ang
Looking for dvd rewritable software supporting buffer underrun
Hi!
I would suggest that you download DeepBurner free version. DeepBurner is a great powerful CD/DVD burning software program which capable to rewrite DVD, create ISO and support buffer underflow technology.
The good thing of this software is that, it is easy to install and easy to manage. If you want to ensure high legal recording, download DeepBurner.
I would recommend that you try out tiny burner. It’s free and can be used for either personal or commercial use. The best thing about it is that it recognizes all optical devices and their related technology. Download
