Looking For FoxitPDF To Word Converter Download Link
I am looking for foxit PDF to word converter download link for my Windows PC and I am unable to find it. I have heard it’s really good and this I need help guys. Please help me. Thanks.
Foxit PDF to word converter is not for download. However, you can visit their website from the given link and you can convert the documents online by selecting the PDF from the browser option and then converting it and sending it to the required email. But if you need to download it for your desktop, you can download foxit’s own phantom PDF which is really good and it provides you with options to convert, merge and create new PDFs. It is free for 14 days of use and then you have to buy it for $9.
If you want to convert a PDF file into Microsoft Office Word format, aside from installing a document converter on your computer, you can also do the conversion online without the need of installing any application. Go to Convert PDF and other documents to Word then upload the PDF file from your computer.
Also, if the PDF file is already uploaded on another website or on your web server, you can enter the URL of the file in the text field. Or, if your file is in your Dropbox or Google Drive, you can click on the Dropbox or Google Drive button and select your file.
Optionally, you can check “Optical character recognition” to use OCR to convert text from an image into an editable text file and then select the language. You can ignore this option if you will not use OCR. Finally, click “Convert file” to start the conversion.
At the moment, the tool supports DOCX to DOC, ODT to DOC, SXW to DOC, RTF to DOC, WPD to DOC, TXT to DOC, PDF to DOC, PDF to word, and HTML to DOC.
