I am looking for links to download tune-up 1-click maintenance for my PC. Many people have told me that it is quite good and is easy to use and I have been looking for some software to maintain my PC. Can someone give me the link to download it?
It is a very good tool that helps you to fix your PC by recognising bad files or bugs, or threats and viruses. It helps then clean them at just 1-click. It also recognises junk putting in your PC and your recycle bin for a long time and help you free space on your PC. It also helps you clear RAM to make your PC run faster.
Looking For Tune-up 1-click Maintenance Download Link
An alternative to “TuneUp 1-Click Maintenance” is PC Tools Performance Toolkit, the one I’m currently using. All optimization methods found on TuneUp 1-Click Maintenance are also available in PC Tools. PC Tools Performance Toolkit’s “1-Click Optimization” feature includes the following maintenance and system enhancements:
Registry cleaning
Privacy cleaning – includes cleaning of Windows history and temporary files, browsing history, and third-party software traces
Windows optimizations – applies optimization tweaks on the system
Disk defragmentation
Scanning of unused applications
PC Tools Performance Toolkit the last version
All these cleaning methods will be executed in sequence one after the other. Download PC Tools Performance Toolkit. Follow the instructions to download and unpack. This is the last version of PC Tools after it was acquired by Symantec and then later dissolved. It supports Windows XP, Windows Vista, Windows 7, and Windows 8.x.
It requires Intel Pentium 4 or faster processor, 512 MB RAM, and 100 MB free space.
1....
