Looking For Xlsx To XLS Converter Online Links
I am looking for links for xlsx to XLS converter online to convert some important xlsx files I have got urgent work with. Please suggest me some links.
Given here is a website link that helps you convert xlsx to XLS without any hassle. It is a simple to use website and you just have to select the file to be converted and then click on convert. Apart from xlsx to XLS conversion there are many other conversions available on the website.
http://convertstandard.com/Xlsx2Xls.aspx
Here is another website that helps convert xlsx to xls files. You just have to select the file of size not more than 50 MB and then you are required to enter the email address you want the converted file on.
The XLSX file format (*.xlsx) is the default saving format of Microsoft Office Excel 2007 and higher. The XLS file format (*.xls), on the other hand, is the default saving format of Microsoft Office Excel 2003 and earlier.
If you have Office Excel 2007 installed on your computer, you don’t need to convert it online because you can do it directly from Microsoft Office Excel by saving the file as XLS. Start Office Excel 2007 then open the XLSX file you want to convert.
Once it’s loaded, click on the Office Button and select “Save As” or just press F12 on your keyboard to bring up the “Save As” dialog. In the “Save As” dialog, in “Save as type” dropdown list, select “Excel 97-2003 Workbook” then click “Save.”
This will then save your XLSX file into XLS format. Now, if you don’t have Office Excel 2007 or higher, you can do the conversion online. Go to Convertio Convert XLSX to XLS. Just upload your file and convert it. You can download the converted file immediately after the conversion. If you get an error when downloading the output file, try signing up for an account.
Another online conversion tool is CloudConvert. The same as the previous online converter, just upload your file and convert. You can download the output file immediately after the conversion and you don’t need to sign up for an account.
Notifications
