Is there any foxit pdf editor mac compatible version ?
The Windows version looks great, and -most important- is free, but is there any alternative to the pdf commercial editors for mac ?
Thank you so much.
Looking for a foxit PDF editor Mac compatible version
Hi Alfredo,
There is no version of Foxit pdf editor that is compatible with MAC OS. You can do PDF editing online also, there would be no requirement of any software or their versions. There are online sites which provide you all tools for editing, creating of pdf files, one of them is www.pdfescape.com. This site will help you in;
>Creation of new pdf file.
>Edit pdf file.
>Fill out forms.
>Password protect pdf content.
>Save and Print pdf files.
If you are looking for a Foxit editor Mac compatible so I want to inform Foxit pdf editor application is only compatible for windows operating system not for Macintosh now but you do not worry about that you can use Acrobat pro X application it has same work same functionality and it is compatible for Mac.
Thanks
Raun Nelson
