neil guyson
Posted on - 02/05/2013
I'm looking for a free matching algorithm software that can easily map our test results to a text file. The program should be able to map the results instantly, so that the test results can be viewed soon after they are produced. Is there any software available for download for matching algorithm?
Looking for a free matching algorithm software
Hello Neil,
There is free matching algorithm software that can easily map out test results in text file. Linkagewiz is a software that map the results instantly. Results can be viewed soon after they are produced.
I am pointing you to a site which offer a download option of the software.
Go to the site install the file and all done.
http://www.linkagewiz.net/
