Kristi
50 points
Posted on - 09/03/2012
I am searching for a free rar file copier software. I want to use this tool to extract files from rar files and copy those files to another location. Please give me the free download link of rar file copier software.
Looking for free rar file copier software
Hi Kristi,
I am also using WinRAR for extraction and make zip files.I have a good knowledge about winrar.
the main features of WinRAR are:
extract and compress files
compress and email files.
extract files in a specified location and in Own folder.
You can copy the files fro one location to another location otherwise you can use the "tera copy" for fast and secure coping.
You can download the WinRAR setup from mentioned link:
http://download.cnet.com/WinRAR-32-bit/3000-2250_4-10007677.html
I hope it may help you. Thanks!
Hello.
After my research I found that WINRAR is the software for you.
Here is the step by step procedure to use winrar.
1. Download and install winrar from the following link.
2. After installing the winrar, open the rar files using winrar.
3. Once you open the file, there is an option called extract. Click on the extract to option.
4. When the extract window opens choose the destination path where you want to save the extracted files and then click ok.
thank you.
