Looking for gadget outlook tasks gadget
Hi Experts,
I am looking for Outlook 2007 Gadget for windows side bar. Please suggest me the best solution for gadget outlook tasks gadget.
Thanks,
Best Regards.
Hi Experts,
Thanks,
Best Regards.
For your requirements, there are two gadgets available, which can be downloaded from the Windows Live Gadget Gallery. They are called Outlook Appointment and Outlook Tasks. These two can be used independently, without opening the actual outlook program.
The calendar shows 3-5 appointments, with emphasized color coding. They can be clicked for opening in the original outlook program.
The Tasks gadget shows all the tasks, with built in scrolling capacity. You can add and edit tasks from this gadget easily. And you can also mark completed tasks. https://support.microsoft.com/en-us/help/13787/gadgets-have-been-discontinued
If you want to use some gadgets then you can find that manually but if you want to find some updated gadgets then i can provide some link. This link will help you a lot and you can find new and updated gadgets from here.
