Looking for Help – Amazing Charts
Does anybody be familiar with if 6.3.3 fixed this error one spots when they release AC?
Please help and give the answer.
Hello Daniel Nicholass,
A very easy, yet effective solution to the problem you are facing is that you need to stop and then restart SQL on the main computer for AC to run.
You should check out this thread regarding your problem:
http://amazingcharts.com/ub/ubbthreads.php/topics/38907/Clients_say_Service_not_Runnin
Hope this helps to resolve your issue
If you are running Amazing Charts on a workstation or on a server, make sure the Amazing Charts service is running either on the server or on your workstation. To check if the service is running, click Start, Control Panel, “Performance and Maintenance”, Administrative Tools, and then Services. Go along the list and look for the Amazing Charts service. See if Started is indicated in its Status.
If the Status column doesn’t display anything, it means the service is not running. You need to start the service to make Amazing Charts work. To start the service, double-click the Amazing Charts service. On the next window, in “Startup type”, select Automatic. Click Start beneath it then click OK then close the rest of the windows. Start Amazing Charts and see if it works.
If you are using an old version, try updating to the latest. Go to Amazing Charts Free Trial to download. This allows you to try a full working version of Amazing Charts for 28 days. It supports Windows Vista Service Pack 2, Windows 7 Service Pack 1, Windows 8.1, and Windows 10.
For servers, it supports Windows Server 2008 Service Pack 2, Windows Server 2008 R2 Service Pack 1, and Windows Server 2012 R2. It requires Intel i5 or faster processor, 64-bit Microsoft Windows, 8 GB RAM, and 1 TB hard drive space or more for servers. For workstations, it requires Intel i3 or faster processor, 32-bit Microsoft Windows, 4 GB RAM, and 16 GB hard drive space.
