Looking for javafx 2 report viewer
Is there already a javafx 2 report viewer which has the embedded PDF viewer? I'd like to put the report viewer in HTML through its API which supports CSS. Where can I find javafx 2 report viewer?
Dear user,
You can download JPedalFX. It is a good quality PDF viewer, which is based on JavaFX 2. Its function is to quickly and easily view the PDF documents. You can read its other features from the download website. The website also provides a step by step tutorial for its download.
Hope this will help you.
Thank you.
Hello Haggard,
JPedalFX Lightweight PDF viewer. It based on JavaFX 2 and the LGPL. Simple user friendly interface and also designed for quick and easy viewing of PDF documents.
