Hi Everyone!
Can anyone please help? I am looking for Joomla interview questions and answers which I can use to gain more knowledge about Joomla. I am a new developer and I would like to apply for a renowned company. They are using Joomla and I would like to ensure that I pass and get the position. What are the important things that I need to know about Joomla?
When it comes to troubleshooting, what are the most common problems encountered by the users and how are you going to handle the problem? What do you think are the important questions to be asked by the interviewer? Can you provide me the basic guide on using Joomla? Any help will be much appreciated.
Looking for Joomla Interview Questions and Answers?
I am pleased to provide you with the possible Joomla interview questions and answers. I hope this will help you pass the interview and gain the position you are applying for. See the attached pdf file. Just don't forget the basic principles of Joomla and get to know the company you are applying for since there is a greater probability that it will be asked by the interviewer. As for your being a newbie, you can browse this site https://docs.joomla.org/Beginners. Happy reading!
Hi Alisa,
The most important question to know the answer would be “What is Joomla?”. You might also want to know advance ways to use Joomla and knowing about PHP and MySQL would give you an advantage.
Technical issues usually arise if system does not meet the Technical Requirements.
Here are a few links you can use to get familiarized:
