Looking for lolcam downloaded for my pc
I want to download lolcam to my pc. I need information regarding this. Will it support pc? If yes then tell me how lolcam can be downloaded for my pc which runs by windows 7. Supply the links for downloading lolcam for pc.
Answered By 10 points N/A #145254
Hello Trish,
For sure you can download lolcam to your PC. You can get this application from third party software downloading sites on the internet. After that you have downloaded to your computer, you can go ahead and install it. But one thing you need to be sure about is that you are downloading a desktop version to work on your PC, for may end up downloading a mobile version that may fail to work properly on your computer.
With lolcam on your PC, you will be able to:
  • make your pictures awesome instantly.
  • take pictures of  your friends as well as family with phrases and also images overlaid on top.
  • share your photos instantly using Facebook or email.
Carl
