Looking for lotus notes connector for outlook 2010
I am desperately looking for the notes connector for my outlook 2010. Please tell me will it support outlook 2010. If it supports then give me the link to get lotus notes connector.
Hi Tracey,
Yes, Lotus notes supports Outlook 2010. You need to download a software called DAMO.
1. Go to https://www.ibm.com/developerworks/develop/collaboration/index.html.
2. Click on download DAMO and save it on your desktop.
3. After downloading the file, double click it to start the installer.
4. Proceed with the installation as directed. You have to enter your Lotus notes username. A new profile will be created.
5. After installation restart your system and start outlook 2010. Select the profile created in step 4.
6. Set the compatibility mode to the administrator rights.
Now your Lotus notes will be connected to outlook 2010.
Hope this information helps you.
Hi.
To connect IBM Lotus with Microsoft Outlook follow this few steps.
1) Download Microsoft Outlook connector
2) Install Microsoft Outlook connector
3) Open Microsoft Outlook
4) Clock Tools and search Account settings
5) Select Account settings
6) Select Email and click Other
7) Search and choose Microsoft Outlook Connector for IBM Lotus
8) Select Next
9) Relunch Outlook
Queen Norman
Notifications
