Is it just me or msdos exe Decompiler is really an expensive application? I want to find out if an old msdos program that I have here was written originally and I badly need an exe Decompiler for msdos. I have reviewed several sites but the cheapest offer so far is $1000. Is this a reasonable price for a Decompiler? Can you suggest a Decompiler with lower cost?
Looking for low cost msdos exe decompiler
Hello.
Ms dos decompiler is available as a freeware and also you can purchase it.
There are many websites offering de compiler for free as well as paid versions.
Try to download the free version and check whether it works.
Click on the below link to download the free version.
http://www.brothersoft.com/decompiler-325891.html
If you are not satisfied with the free version then download the paid version.
Thank you.
