Looking for mATX board integration process
Anyone with the board mATX? What I am looking for is that,
I will integrate mATX with i5 2500k and an EVGA GTX 560Ti SC DS no SLI as of now.
anyone with any idea how this will respond or react?
Most motherboards these days would have at least one expansion slot for a discrete graphics card. This should include micro ATX motherboards. That said, if you will only be using one graphics card on your system, then using a micro ATX motherboard should not be a problem. If you plan on doing an SLI setup later though, and you plan on still using a micro ATX case, just make sure the motherboard that you choose has support for SLI. This may be unlikely though as micro ATX motherboards usually have fewer expansion slots. Consider you future plans for your rig as well then decide if you would like to go for a micro ATX setup.
