ruiz harrer
30 points
Posted on - 11/01/2012
Hi,Â
I m using Mac operating System. I am looking for mega manager for mac OS.Â
Install it from internet but it does not work in my operating system it show the message "it does not compatible with Mac operating system" if anyone have compatible  mega manger with Mac operating system please suggest me as soon as possible.
Looking for mega manager for mac os
Mega Manager is a useful and reliable application which enables you to download any files and folders from Mega Upload smoothly.
I understand that you are finding it very difficult to download mega manager that is compatible with your mac operating system.
I suggest you should try these two I have found on the internet for you.
Click the links below to download the one of your choice:
1:Â https://mega-manager.en.softonic.com/
2:Â http://ptf.com/download/mega_manager/4512/
I hope I have helped you.
Hi
There are many features in the mega manager that are really nice to use.Â
You are having problem installing the mega manager in your mac OS.Â
You may try this link :Â http://www.brothersoft.com/mega-manager-292445.html
Hope these shall help you.
