Dear All,
I want ms SQL query to generate a calendar.
I am looking for a MS SQL query which generates a calendar and includes month, date, year and day as its basic elements.
So Please provide me the script which executes ms SQL query to generate a calendar.
I would appreciate your help.
Thanks in advance.
Looking for ms sql query to generate calendar?
Hello McLeod Holcomb,
I think "MySQL query builder" software can solve your problem easily. It's enabled to create your desired calendar. Also, you can use some other calendars from this website:
https://en.softonic.com/s/mysql-query-builder.
If you think you are not able to do this perfectly, you have to go to an institute or a farm to solve this issue.Â
Have a nice time.
