Looking for PDF metadata open source editor
Looking for pdf meta data editor use autometadata it is open source having good features like editing number of pdf documents you can download it from softpedia website go to office tools category then select pdf then search for autometadata and it is low in size.
Read specifications before installing.
Hope these shall helps you
Thanks
Hello Louise Rios,
You can get PDF metadata open source editor from the internet, for Windows Vista you can get a hexonic PDF metadata editor which is a free tool and is very fast and easy to use, it can be able to modify a large number of document at once.
Notifications
