Looking for the rar explorer software
I am looking for the rar explorer software to view rar files on windows 7.
Provide the direct download link of rar explorer software.
I know a great little software for automatically unraring rar archives. It's called "RarZilla" .
The program does a wonderful job of unraring.
you can use three ways to do your work successfully from this software.
I am telling you a way and it is the easiest way to how unrar files from RarZilla.
"open rarzilla > optiont > select file > drag and drop rar file to onto the program interface > start unrar"
& you can download RarZilla directly from below link :
download.cnet.com/Rarzilla – Free – Unrar/3000-2250_4-10647724.html
I don’t see the reason why a RAR explorer is still required if you can install a file compressor such as WinZIP, 7-Zip, and WinRAR. These applications can instantly open and extract the contents of any compressed files as long as they support the format of the archive. One fine file compressor that I’ve been using for several years now is 7-Zip.
It renders better compression ratio compared to the other two and the best part is it’s totally free unlike with WinZIP and WinRAR that requires serial for activation. With 7-Zip, you don’t only get a high-compression file compressor but a free application as well that doesn’t require further activation. You can download it from 7-Zip for Windows.
It supports Windows 98, Windows Millennium, Windows NT, Windows 2000, Windows 2003, Windows 2008, Windows XP, Windows Vista, and Windows 7. For users running other operating systems like Linux and Mac OS X, you can download it from 7-Zip for Linux and Other Platforms.
Notifications
