Do you have any rational suite screenshots for rational PureCoverage? Does this show which parts of the code have been executed during all of the tests (assuming more than one test) otherwise if one test doesn't cover that part of the code another test might cover it, but there is the need to discover which parts of the code have not been covered by any tests, can it find this?
Looking for rational suite screenshots for rational PureCoverage
You need to first mention which IDE environment you are using. You need to use code coverage if you are using the Microsoft IDE environment. Through the code coverage method you can check how much code is not being tested and hence you can analyze, how much testing is left. Undoubtedly, testing is most important and for that you can use this software to identify how much testing is left. Thus, you can insure how much testing is left and how much testing you need to assure that everything is correct.
