Amy Bate
40 points
Posted on - 04/28/2013
Hello Guys!
Does anyone know how to create a simple rotating banner flash template? If so, can you share your expertise and tell us how to create a template? Also, if you can provide a simple tutorial, it would be very helpful.
I am not very good with html and I want to learn how to create my own template. Can anyone give us tips on how to create a rotating banner template? What is the easiest and best tools to use to create a very good rotating banner? Please guide me.
Thank you.
Looking for Rotating Banner Flash Template?
Hi Amy,
I suggest Ad Butler which is a tool which will help you handle your advertisements online, plus, it’s not difficult to use; https://www.adbutler.com/. It measures from thousands of impressions on small websites to billions a month. Ad Butler gives professional options at reporting and thorough management of your ad servings. Phenomenal support, competitive and upfront prices and provides almost a hundred percent accessibility with not even one devise and server disappointments. Has 30 days trial included
