I found this Samsung apps Chinese handwriting input called gPen but its ok but after and update the caps lock button doesn't work anymore. Now I need a new one since it doesn't function well anymore.
Thanks for your help!
shawon
Looking for samsung apps chinese handwriting input similar to gPen
Hi Sharlene,
First of all in your question you told that, you are facing some problem in Samsung handwriting impute process and wanted to know about new from Samsung. My suggestion for you that, there are lots of traditional languages have not need any capital or small letter option. The Chinese language is one of them.
But in English you should need the caps lock button option. You also want to know about what new and that would be much better option for you. My idea is SAMSUNG GALAXY S III (16 GB). It is the recent and much smart product by SAMSUNG. Really it would be a smart option for you.
Thanks
Best wishes,
Shawon
