I am looking for a software that can check network system disk space. I hope you can recommend some programs. IF possible it is a free ware and with extra functions like disk management, etc. Hope to get some help. Thanks!
Cianch
Looking for a software to check network system disk space.
Good day!
There are several options regarding software choices that are free. Here are some:
1. CCleaner
– I personally recommend this one because it comes with a PC Optimizer to check your computer stats, clear up RAM and Internet Caches. Before "optimizing" your PC, it will display the status of your computer overall including the registry. I myself use this to improve the performance of my pc. And the best thing is, it is for free! You can download it here: http://www.piriform.com/ccleaner
2. SpaceSniffer
– Although not a PC Optimizer, this is a standalone software that doesn't need to be installed and very easy to use because of the somewhat "oldy" feel of the interface. SpaceSniffer is also free and can be download from here: http://www.uderzo.it/main_products/space_sniffer/download.html
Hope I have helped you in any way! Thanks!
It is very importance to routinely check the disk space for efficiency of the machine to be beefed up. You might be required to use the “df” command to get information about the remaining space. The command is illustrated as below.
Filesystem 1024-blocks Used Available Capacity Mounted on
/dev/sda1 1888052 135908 1654551 8% /
/dev/sdd1 4299828 100084 3977246 2% /archive
/dev/hda2 3048303 897858 1992794 31% /archive2
/dev/hda1 11677 1380 9694 12% /boot
/dev/sdc1 4299828 350310 3727020 9% /home
/dev/sdb1 4299828 598504 3478826 15% /usr
/dev/sda2 1888083 700414 1090075 39% /var
/dev/scd0 593958 593958 0 100% /cdrom
Alternatively, the programs that can be used for this purpose include overseer, folder sizes and check. They can be downloaded from their respective websites.
Hello Michelle, there abound hundreds of softwares on the internet. You just have to go to sites like www.brothersoft.com and search for it there. In the meantime I hope this software (foldersize) will be useful for what you have in mind. You can get it here: www.foldersizes.com/ I hope this information is of assistance to you.
I can suggest you two tools for your different two tasks. The first one is to look for free disk monitoring software. It allows managing disk space of your network disk and also it will serve you to manage others disk space. It is a great tool without limitation with a good interface. Download it from here. The second is only for disk space monitoring and managing. Here it is.
