Looking for team assign download
Hi Experts,
I am looking for team assign. I have downloaded but after installation, when I start this application. It shows some kind of error : .dll missing,
Please resolve this problem and send me the trusted link for downloading problem free version.
Dudley Achan
Best Answer by Sharath Reddy
Answered By 0 points N/A #148000
This seems to be the problem of windows dll files. But you need not to worry as you can install it manually.
Some of the required dll files are missing from your system.
You must check for the exact file name in the error.
Then do the following to get your issue resolved,
1. Visit this link and search for the desired file name (Link: https://www.dll-files.com/) It’s a trusted website so you do not have to worry in downloading.
2. You can also use this handy tool to automatically fix such dll files missing errors. (https://www.dll-files.com/fixer/)
Answered By 590495 points N/A #148001
Too bad you did not mention the URL of the website where you exactly downloaded the file so we can better check it for other versions. Since the problem here deals with a missing “.dll” file, we can assume that your previous installation has gone wrong and resulted to corrupt some of its installation files. You may try to do another clean installation on the software to possibly fix any corrupted files that may have developed when it was installed.
Uninstall Team Assign then restart your machine when asked. After booting, check your computer for any possible errors. Use a disk utility application to check the system. Install the software again then see if this fixes the problem. If you still received the error with the missing dll file, you may visit DLL files to download the missing file. I think this is the only website where you can download missing dll files from different software. It has great collections for this kind of library file.
Answered By 0 points N/A #148002
All of your solutions are helpful, thanks guys for your suggestions. Sharath Reddy, when I read your comment I realized why this problem occurred and how to fix it.
As you suggested, I uninstalled Team Assign and restarted my computer. Then I used a disk utility application to check my system. When I re-installed the software after that, I saw that the problem had gone. I am no longer getting any error messages. The link you provided is excellent.
Your right, that website has a great collection of library files where I can download missing dll files from different software.
