Looking for text file split merge utility
Can anyone suggest a simple to use text file split merge utility software? I need to split some GB .txt files and merge the other MB .csv files. I need this tool to consume less than 1 MB of memory. I still use Windows XP 64 bit sp 2. Thanks.
