Looking for a tiff to avi file converter for Mac
I have some tiff files that I want to convert into avi files for mac computer. Please mention a name of the best tiff to avi converter for mac.
Greetings Oraliarfielding, upon reading your question my suggestion for you is to use the Wondershare Video Converter Ultimate.
It supports all types of Windows and Mac OS, and in addition this is a very powerful tool for converting your video files, and not only tiff files you can convert. this software supports most of video file format.
So i strongly suggest that you give this software a try. heres the link for the software:
If you need to convert your TIFF files into AVI video format, try using TIFF to AVI Converter. It works on Windows 2000, Windows 2003, Windows XP, Windows Vista (32-bit or 64-bit), Windows 7 (32-bit or 64-bit), and Windows 8. This is a great tool if you want to convert several of your TIFF images into a slideshow in AVI format.
The program allows you to convert TIFF images one-to-one. You can also combine the input files into one larger video. The application also lets you configure the slide speed. Aside from creating a slideshow out of the TIFF images you may have, you can also create a time lapse style movie. The output video is only a few seconds long and doesn’t have a soundtrack since the program doesn’t provide an option to add one.
