Is there any way to add a prefab functionality to Inno? I need one that can quickly add and remove various customization and where I can manually incorporate the desired customization into each script. By the way, I need it in version of Turkish for innosetup script. Thank you!
Looking for Turkish for innosetup script version
Inno setup is described as a script-based setup tool because its instruct you to create a package that stored in a simple text, or a script, to understand a simple use of an English words and abbreviations. You can able to create your script in no time.
To get started with the Inno setup, you can download on any website to copy and installing on your computer. After installing Setup you will have it on your start menu. To set up Inno choose the Inno Setup Compiler from the menu and now you can edit any scrip form Inno as it has an own editor for creating and editing the script file.
