Looking for Visual studio source code for voucher
Techyv, I'm in search for Visual Studio Source Code for voucher.
Can I ask if someone knows a web address which really have a sample workable code I can use?
Urgent help needed.
Best Answer by Jeremy J McPhail
Answered By 50 points N/A #193814
Hello Marsh,
Hope you are fine.
You need a visual studio source code. You will get a lot of source code though some simple steps.
At first go to https://www.yahoo.com/ and then write “visual studio source code” at the search bar.
Then click “images” under the search bar. If you want the image.
If you want video then click “video” at the right side of "image"
Here you will get many video tutorials.
It is easy and simple. If you cannot do then go to this link and download your desired source code.
Source code
Hope you will get answers.
Answered By 10 points N/A #193815
Hello Marsh,
OxyProject Metrics is an application that provides code metrics for software projects empowering software professionals to assess the complexity.
Use the following links:
Hope this solves your problem.
Answered By 10 points N/A #193816
Hi Marsh Drake,
If you are looking for the sample system for a voucher you can visit this website "http://www.planet-source-code.com".
They have plenty of system for free download and you can ask for help on the experts about the system you want. If you're like me you will love this site for it is friendly and you will learn a lot.
I hope this will help you.
