Good Day Everyone!
I am looking for windows media center undelete tool. Do you think it is possible to recover deleted files in windows media center? I am using Windows 7 and I try to clean up my files but I accidentally remove the file that I don’t want to be removed. Can anyone help me please? I need to recover that file because it’s a family album which has a sentimental value to me. If you have ways of recovering the files or if you have used a recovery tool then please help me.
Thank you very much,
Alicia Gracee
Looking for Windows Media Center Undelete Tool?
Hello ,
Hope you are fine,
At first look for at recycle bin if everything there you can restore it easily by click restore from left click. If it is not we can use recovery tools like this data recovery ,,,, , recover accidentally
Or you can use these steps from windows media player
Open windows media player from all programs
Go to library from the file menu by clicking add to library
Click on the advanced option in the add to the library dialog box
Click on monitored files
Check files monitored and want to recover
Click OK to start search
Look at files added after search completed and restored it
Regards
