Hallo! I recently installed a pc time limit in my computer but it seems like it did not install correctly and therefore I am not able to use it. When I check the programs at the start menu, I find that the folder is empty. I have tried to uninstall it but it seems this is not possible the normal way. Is there a pc time limit uninstall that I can use to make sure that I uninstall the software? Since I want to remove everything associated with the software, what does the uninstall remove?
Looking for a working pc time limit uninstall
Hello Dallas,
As you mentioned you doubt the software you tried to install was not installed properly so you are unable to un-install. Here is a freeware software for windows is Ccleaner that will be able to uninstall any broken installation as well as it will remove some of the registry file who are included with this installation. You can give it a try and you will be able to uninstall the broken installed software. Here is the link for the software:
http://www.piriform.com/ccleaner
Let me know if your problem get fixed.
Thank You.
