Looking for a working USB flash drive tool
I am just wondering on how can I get this movie  in avi format working when the USB is inserted on DVD players that have a USB port. I tried and failed it over and over again. What I did is burn the movie onto a DVD and play the media through it. How can I get this thing working on USB? What specific USB flash drive tool I am going to use? Any comments and similar experiences?
Best Answer by Stark P Blake
Answered By 0 points N/A #170057
Hello
Easiest way doing this is to make dvd rip and then save that dvd rip to usb flash drive. I recommend using Ashampoo burner. So open Ashampoo burner (depending on version) select option for making dvd rip. After process is complete insert usb flash drive and copy your ripped movie onto usb flash drive. Now you can watch your movie from usb drive.
Regards.
Answered By 0 points N/A #170058
Hello Namat,
You can watch your USB stick’s movie by ripping them on your PC. For ripping I suggest you to use “Nero 12”. This software has powerful features to rip a movie. This software is a total audio/video solution for editing and ripping any CD/DVD. After installation select DVD from dropdown menu from the main window and then select DVD rip. After successful ripping  transfer the file into your USB stick and play it from your DVD player.
