Loop for Multiple Image in Visual Basic
Hi! Can you help me figure it out if it could be possible to use loop to store multiple image in database access 97?
It’s remains a difficult task. Or even impossible to use loop to store multiple image in database access. So if you want to do that, you might be facing a lot of problems. However I’m trying to Simplify a little bit.
Actually, when you try to loop images there happens some problem obviously. If you described a lot may be here I could open a way. You may visit this site- http://www.dreamincode.net/forums/topic/231852-trying-to-loop-images/
Here I suggest you at another site that may be giving you more solvency.
Hope this may work. Thanks.
