I recently heard a ring that can control most of your devices and appliances at home. This so called ring how much is it? Is it already out in the market? Where can I buy it? Can I use it to control my phone or to make payments? What are the devices that we can control with this ring? How does it work? What are the materials used to manufacture this ring? Who invented this ring?
Lord of the Rings True-to-Life Gesture Device
Hi Mellisa!
You can purchase it directly to LogBar and they will ship it to you. This device is limited only for those who will purchase it. Yes, you can use it to make payment if the LogBar software and driver is properly configured to your smart phone. LogBar is predetermined and with the starting amount of $145 per piece. The amount of this device is actually extending now for about $165.
You can control most anything in your house. This is properly and tested with iPad, iPhone, Android Phones, Google Glass, smart watches, any devices in your house with automated system embedded.
This ring can alert you also any updates from your cell phone. You can also teach the ring to recognize your handwriting by using the software with. Materials used for these device is motion sensor, Bluetooth Low Energy (BLE) and also a touch sensor embedded from the outside core of the ring. The material used is zinc. This will include a charger bar and USB connector.
In ordering this ring you have to ask for pre-order to make it sure that it will fit your index finger. If not, every gesture you do it will fly or fall-off.
