savchu
20 points
Posted on - 10/31/2011
Hi All,
I am running a Music Editor on my computer which has Windows XP Pro Operating system. My issue here is I am losing my access to open programs and even Windows explorer. I wonder what would be the problem because there is no problem with the specs of my computer. I have 4bg Ram and a dual core processor but got tons of large files on my drive. I would greatly appreciate any help. Thank you!
Losing access to open Programs
Looks like you had a good system. So I would not say that you need to change any hardware. But there can be two type of problems both are related to software one is virus attack and other is Operating system. If its virus attacks then you have to use a good antivirus to solve it. I would suggest you to useNORTORN2012 for this problem. Because it is the best on this types of problems. If it is not virus then you have to change your operating system go to Windows XP service pack three or go to windows seven. At end my last advice is if you can then make partition to your hard disk.
