Lost Connection to Server when playing PES 2012
I just purchased Pro Evolution Soccer 2012 on my PS3. I always got this error on connecting to server. The error says, "Lost Connection to Server". But when playing the older versions such as 2009 and 2010, it works well.
How can I get rid of it?
Need help.
Answered By 10 points N/A #103600
Hi
Are you using a wireless or a wired connection? Have you considered using a local area network(LAN) cable i.e. a wired connection to play?
You can try the following steps to improve your internet connection.
Start your PS3 and go to Settings. Select Network Settings  and go to Internet Connection Settings.
Then choose Custom > Your Preference (Choose Wired Connection or Wireless) > Manual Settings > Auto-Detect > Manual > Here you will setup OpenDNS and a static IP.
Now copy the following to your PS3
IP Address:             192.168.1.1xx    (Replace XX from 01 to 99, pick any number in between. E.g. 192.168.1.105)
Subnet Mask:        255.255.255.0
Default Router:       192.168.1.1
Primary DNS:        208.67.222.222
Secondary DNS:    206.67.220.220
Under MTU, select manual and then select 1500 > Do Not Use > Enable > then save the new settings.
You could also try to disable the router’s firewall function. Just use the following steps:
https://www.wikihow.com/Disable-Router-Firewall
