Lost my uninstall button on add/removes
I cannot delete FIFA 11 from my PC because I have lost my uninstall key. Can anyone help or tell me the alternative un-installation?
You can get back the uninstall key and uninstall FIFA 11 to do the following:
First, Click on the Start then goes to Run and type regedit. Navigate plus following
HKEY_LOCAL_MACHINE>Software>Microsoft>Windows>CurrentVersion>Uninstall><FIFA11>
Do the following in the right panel:
First Double-click NoRemove (REG_DWORD) then set it to 0
Again Double-click NoModify (REG_DWORD) and set it to 0
If NoRemove is set to any number that means the change button is unavailable
If NoModify is set to any number that means the change button is unavailable.
You can back uninstall button through this work. You can uninstall the game by going in the installed directory. Go there and you will find a (recylebin logo) file named Uninstall. Double click on the file and follow the steps and the game will remove successfully. I think the answer will help you.
Hallo Alex,
That means that you cannot uninstall any program from the control panel. It appears strange but then things happen. Have you tried restarting the computer and see if the uninstall button can be retrieved?
But you do not have to worry. You can still delete your FIFA 11 from programs files under the primary hard drive. Just open my computer and the C drive. Look for program files and then click on it to open it. Look for the folder that has the FIFA 11 program and open it. From the list of files listed look for the un-installation program and click on it. Your FIFA will be successfully uninstalled,
__
Regards
Mahesh Babu
