Lost “track changes” in Outlook 2010 Beta
My computer has lost “track changes” which I use to edit mails in Outlook 2010 Beta just as in Word 2010 Beta. Could it have been removed and is there is anything else that I can do about it?
Hello Barclayn,
First thing, there is NO track Change option in Outlook 2010 or even in outlook 2007.
However, there is a workaround, if you want to point out some changes on a particular word. And that is “comment” on a word.
In order to use this, you have to first open the particular mail, select the particular word, then go to message from the bar, locate and click on “Actions” and click on “edit”.
Now press Ctrl+Alt+M, you will now have the option to add your comment to a particular word.
Refer Fig:
But most of the time people do not use this option; rather they use the sticky notes option.
Or they spend money on “One Note”.
Rogers
Hello Barclayn,
That is a bit weird but you can still restore the tracking on Outlook 2010 beta using the following workarounds:
The tracking should work well after that.
Hope this helps.
Carl
Notifications
