Is there a way to retrieve Vaio blu ray driver after having deleted it by accident ?
Maybe it depends on the physical machine, especially the motherboard, besides the blu ray reader itself.
Where may I find the specifications of my driver on my computer ?
Lost vaio blu ray driver
There are a two solutions that I would give you and you can choose what to try to fix your issue.
1.You can make recovery of deleted files and drivers with VAIO System Recovery. On the boot screen press the key F10, a few times till you see the System Recovery Options and then follow the steps and install all software after the boot.
I will give you a link with more step by step instruction how to do it:Â https://www.techwalla.com/
2. On this link below you can find and download drivers for your laptop: https://www.sony.co.uk/electronics/support/personal-computers , just write your model name and click find support. Â
Williamson Mellisa
