Lot of errors and configuration issues
I've been using VistaPE for quite some time now. Building and re-building, adding and testing scripts, all for the purpose of running anti-spyware & anti-virus scans on troubled PC's. It's been an invaluable resource.
With this update though, I've been having a lot of errors and configuration issues. I’ll provide as much detail as possible but I'm sure there will be questions.
Processing Scripts…
All selected scripts are being processed, Plesase wait until this sequence is completed.Aftar it. concludes this stag you can view more information inside the log tab.
Script
 PostConfig [00-postconfig, script]
Finalizing Vista PE…
Messages
Processing commands..
Progress
Bcdedit.exe-Entry Point Not Found
The procedure entry point DwnHint DxUpdate Could not location in the dynamic link library USER32.dll.
