Lotus encryption outlook is not being done
I am using outlook for my mailing purpose but when I use lotus notes I face a problem of Lotus encryption outlook. I need help in this issue please help me how can i solve this issue.
I can give you link to have clear understanding about your problem. I will share what’s your problem about and how to gain the procedure/steps to have a successful lotus encryption outlook.
http://www.selfgrowth.com/articles/get-rid-of-lotus-notes-encryption-via-nsf-to-pst-file-conversion
https://itstillworks.com/advantages-disadvantages-symmetrical-asymmetrical-encryption-2143.html
They have all the steps to pursue this problem and to have enough knowledge if that problem exist again in the future.
Thank You.
The problem aroused because of using both the programs interchangeably as Lotus Notes has the NSF file format while Outlook has a PST file format.
To overcome this issue, you have to convert the files before switching from Lotus Notes to Outlook:
Open Lotus Notes then click File->Export and select the type of format either "Tabular Text" or "Structured Text;" Continue through the "Export" wizard by choosing a file location and create an exported file.
Open Microsoft Outlook then click File->Import and Export-> Import from another program or file .Click "Next" then choose "Comma Separated Values (Windows)" or "Tab Separated Values (Windows)" depending on type to export the file as and click "Next" to browse for the file, select and then click "Open." Continue through the wizard, by clicking "Finish" at the end, to finish importing the Lotus Notes file into Outlook.
Hope this helps you better.
