As of today, our company is using Lotus Notes 7.0.1 in our client-end and Lotus Notes 6.5 in domino server. I want the easiest and possible ways to generate an auto replication and after replication. The concept is to display all the latest emails and automatically delete the old emails that are no longer needed. Can someone please help me with this? Thank you.
Lotus Notes and Domino Auto-Replication
Hi friend,
There are many ways to auto replication for lotus notes. In between Lotus Notes 7.0.1 as client and Lotus Notes 6.5 as domino server it is not so difficult to find the easiest way to auto replication. You will find many ways but which is easy that depends on you. In my eyes this process is easy for auto replication.
I was used to space server option for auto replication. To do these go to Replication settings from the menu window.
Here in mode setting option select “remove docs not modified in the last 30 days”. It will work and emails will last only 30 days in server.
