Lotus notes com windows live
Yes, you can find a software that will migrate Windows Live to LotusNotes. You can download the software for free
It is required that your system has:Â Pentium II 400 MHz, 64 MB RAM, 10 MB. Â Scroll down to the bottom page and you will find free links.
There is another software called SysTools that will migrate Windows Live Mail to Lotus Notes exporting Windows Live Mail messages as well with EML to NSF converter software. Please note that SysTools is not a free software and you can purchase it from this
However, free convert Windows Live Mail Emails to Lotus Notes demo is available. SysTools run on 32-bit and 64-bit window versions. SysTools get installed in the following location:  C:(or any directory where your Windows are installed)Users<userlogin> AppDataLocalMicrosoftWindows Live Mail
I hope this is helpful.
