Lotus notes command to distribute emails automatically to several people
I’m not sure if Lotus Notes can distribute files through email to several people automatically and daily. I wanted the files to be generated every day and will save permanently into a file server. Any idea if Lotus Notes can do such distributing? If not, what are the possible software programs to do this kind of task?
Answered By 75 points N/A #114517
Hi Carmelo,
You can always download that can of software through internet and most of them are in "trial period" meaning, it will expire once it reach to it's deadline and this is not appropriate to your needs because you want a customize software which you mentioned on your problem. The solution here is to get the customize software for this that automatically do the task require. We can guarantee you will be contented on the results, because it will take some time to finish the program, the process is really end to end and 100% no error. I recommend to contact on ACCUPOS SOFTWARE, you can search that on the internet they provide you a free software and just contact them where you want to customize your program and the fee is very affordable.
Thanks,
Tony Stevenson
