Lotus notes daily calendar widget
Hi All,
Suggest me the best IBM Lotus Notes daily Calendar Widget, that will help me to organize myself with reminders and self notifications,
Please do the needful.
Thanks,
Angela D Sloan
Hi All,
Thanks,
Angela D Sloan
Hello Angela D Sloan,
The best IBM Lotus Notes widget for your needs seems to be Tungle because you can set as much as appointments and reminders as you want and also it is connected with your Google calendar, so if you have a Google account you can sync it with Tungle and all the hard part is done.
Take care.
Hi Angela,
You can use ScheduleOnce to your IBM Lotus Notes; it can manage your appointments alongside with your other commitments without getting double booked. It is also integrated with Google Calendar and you can also use the Google Calendar to Connect to your Outlook, iCal and other calendars.
I hope this will help you.
