Lotus Notes Error while opening windows
I am getting the following error message with Lotus Notes. ‘While opening the window error is occurred’. Please help me to fix the problem.
Thanks in advance.
Thanks in advance.
Hi Dorothy,
This problem usually occur due to closing unexpectedly one or multiple programs. A various process were running when stopping them forcefully while Lotus Note is open causes this problem. Well to simply remove the error we need to literally kill it. This procedure should do; Run your Lotus Notes then go to Run.
Type nsd-kill or you can end the ntaskldr.exe and restart your restart your machine. Then check your Lotus Note it works like a charm
Hope it helps.
A.Wright
This problem could occur due to some bug in lotus notes. This could be solved by updating lotus notes to the latest version. You can get the latest version of lotus notes from. Once you have downloaded the latest version of lotus notes. Run the setup and then select update instead of install. I hope this helped.
Peter franklin
