Muskan
Posted on - 08/27/2011
Lotus notes. How can we reroute all incoming mails to local?
I am new to lotus notes and need help with it. I want all emails that's received to move with a rul to local pst in lotus not sure what they call it. How can i move all to the local as they arrive.?
Thank you
If you want to reroute all incoming mails to local server then you need to do some work. It will be costly. You can redirect any of your mail from Google or yahoo or others mail box. For this you need to follow up some steps. First you need to login your mailbox and set redirect option and active it. Then you need a mail server to store mail. So you need to set up a mail server for this. Then there are some rules for redirect mails. So after mail server you need to create some server mail rule that store mail in the special mail database. And make a forwarding rule just inside the mailbox.
